I've got a polygon with thermal enabled and some 6mm x 6mm buttons where the ground pads have thermal pads. What options do I have in eagle (old 7.3) to lessen their connection to the polygon? They are not high current and don't need the 4 traces to ground. My hardship is that they can be a pain to solder because the heat is being leached by the plane itself. If I turn the polygon thermal option off, then they are solidly connected to it with no breaks which is even worse. I was thinking of some way to separate them from the ground plane and perhaps I just route a wire from them to it if that is possible. Ideas?
