Author Topic: Trace top and bottom layer at the same time?  (Read 3563 times)
Offline fubar.gr
  • Country: gr
    • Fubar.gr
« on: September 14, 2016, 10:16:36 am »
This is a relay and a terminal block.
To double the current handling capacity, I thought of running the traces from both top and bottom layers.
To do it, I routed them on the bottom layer and then ran a identical wire on the top layer (because Eagle won't let you route an already routed signal).
In this particular case it is not much of a hassle, but I was wondering if there's a more automated way to run traces on both sides of the board?
Offline Karel
Re: Trace top and bottom layer at the same time?
« Reply #1 on: September 14, 2016, 12:10:22 pm »
Yes, you can. To start routing without an "unrouted wire", enter "route", keep the the Ctrl-button pressed and click on a pin, pad, via or trace.
As far as I know, no.
The difference between theory and practice is less in theory than
the difference between theory and practice in practice.
Expensive tools cannot compensate for lack of experience.
Offline batteksystem
  • Country: hk
    • My ebay store
« Reply #2 on: September 14, 2016, 12:35:42 pm »
Usually besides routing both layers, put some via to increase the heat dissipation between the two layers.
Offline Josephine85
« Reply #3 on: September 20, 2016, 11:42:13 am »
Hello,
maybe you´ll find something in the guided tour: https://cadsoft.io/tour/. There three videos about 1) Routing Signals, 2) the Follo-me-Router and 3) Autorouter.
Best regards,
Offline Unordung
« Reply #4 on: September 26, 2019, 02:27:39 am »
Hi guys,
Sorry to revive a long dead thread but does anyone know how this is done in Eagle 9?
It used to work just holding down control but alas its not working anymore and I can't figure it out.
For clarity I am trying to increase the current handling ability of the trace and I'm unable to increase the trace width.
« Last Edit: September 26, 2019, 02:29:38 am by Unordung »
Offline rachaelp
« Reply #5 on: September 28, 2019, 10:43:23 pm »
You need to turn off the loop removal feature of the route command, then it should let you create the additional routes.
Best Regards,
Rachael
I have a weakness for Test Equipment so can often be found having a TEA break (https://www.eevblog.com/forum/chat/test-equipment-anonymous-(tea)-group-therapy-thread/)
