You could try starting with this:/* Set mark before running. */
/* Make sure your grid has the right units ! */
/* Make sure layer is set as desired. */
real height = 25; /* Height of bounding box. */
real width = 25; /* width of bounding box. */
real trace = 0.2; /* Trace width */
real extraSep = 0; /* extra separation between traces */
real epsilon = trace;
string cmd, s;
sprintf (cmd, "set wire_bend 0; wire %f (r 0 0)", trace);
real y = 0;
real x = width;
while (y < height) {
sprintf(s, " (r %f %f)", x, y);
cmd += s;
y += 2*trace + extraSep;
cmd += s;
if (x <= epsilon) {
x = width;
} else {
x = 0;
cmd += ";\n";
// dlgMessageBox(cmd);
exit(cmd);
