Author Topic: Using polygons  (Read 1456 times)
Offline Karel
Using polygons
« on: January 29, 2016, 09:50:25 am »
How to get the best out of the EAGLE polygon (copper-fill) function:
http://www.eurocircuits.com/blog/238-using-polygons-in-eagle
Offline generic_username
  • Country: at
Re: Using polygons
« Reply #1 on: January 29, 2016, 10:00:20 am »
only thing I didn't know up till now is that you can turn orphans on and off, but sadly I don't see in that blog where that option would be.
I always need 3 attempts to plug in a USB connector
Offline H.O
Re: Using polygons
« Reply #2 on: January 29, 2016, 10:20:56 am »
Where have you looked? Here are four different ways, there may be others as well.
* When you select the polygon tool you can activate/deactive orphans with the buttons in the toolbar. I believe this is modal so the selection is kept.
* Change -> Orphans -> On/Off -> Left click polygon outline. This is also modal so next time you draw a polygon it'll be with this selection.
* Info -> Left click polygon outline -> Checkbox Orphans (they show that dialog in the blog post)
* In the command line type Change Orphans On (or off) -> Left click polygon outline.
  • Country: at
Re: Using polygons
« Reply #3 on: January 29, 2016, 11:31:52 am »
i see thx ;)
i never knew there was an option as I already had them turned off (default?) but it is nice to know where to change if needed.
