Author Topic: Wire pads without drills?  (Read 2199 times)
Offline stryker
« on: September 03, 2013, 09:25:59 pm »
I'm replacing a board which has a row of connectors on one end that are sandwiched into the case and make contact with a row of springs.  To replicate this I'm thinking I'd modify a wirepad to not have a drill but before I make my own - has anyone seen something like this in an already available library?
Thanks
Geoff
Offline kizzap
Re: Wire pads without drills?
« Reply #1 on: September 04, 2013, 12:43:20 am »
Easiest way to do it is make a package using SMD pads at the appropriate size/spacing.
<MatCat> The thing with aircraft is murphy loves to hang out with them
<Baljem> hey, you're the one who apparently pronounces FPGA 'fuhpugger'
Offline babysitter
  • pushing silicon at work
« Reply #2 on: September 04, 2013, 04:42:06 am »
TP* might bring up what you look for.
I'm not a feature, I'm a bug! ARC DG3HDA
Offline stryker
« Reply #3 on: September 04, 2013, 12:36:31 pm »
I think those test pads will be just the ticket - thanks !
