Author Topic: [SOLVED] [ORCAD PCB] Save all color views?  (Read 1325 times)
Offline Pack34Topic starter
« on: August 30, 2021, 01:09:15 pm »
I'm trying to make it easier on myself when starting a new layout to be sure that everything is consistent. Currently I just have an excel spreadsheet to help me setup all my layer views. However, this can be a bit of a chore when setting up a new board, it only needs to be done once, but still. I've then switched to saving each view individually and then loading them in a new design.
Is there a way to save all the views at once?
« Last Edit: August 30, 2021, 06:38:30 pm by Pack34 »
Re: [ORCAD PCB] Save all color views?
« Reply #1 on: August 30, 2021, 06:38:16 pm »
It looks like that's what the "Save color parameters" does.
Online nctnico
Re: [SOLVED] [ORCAD PCB] Save all color views?
« Reply #2 on: August 30, 2021, 09:44:16 pm »
You can also export board / color parameters (under export -> more) to a file and import them into a new design.
