Author Topic: 2 Different Supply Voltages on PCB  (Read 1847 times)
Offline jones12Topic starter
« on: April 23, 2018, 12:24:57 am »
Hey guys,
Im designing a simple PCB with an ATmega328P to switch some fans on and off through a MOSFET.
I need 5v for the IC and 12V for the fans, not huge power from rough calculations about 1A on the 12V side and roughly 1A on the 5V side.
I was planning on using a 12V SMPS into a 7805, and tapping off the 12V incoming but I've been told that's not a good idea as it will get too hot.
What are my other options? Hoping to keep this as compact as possible.
Cheers guys!
Offline killcode
Re: 2 Different Supply Voltages on PCB
« Reply #1 on: April 23, 2018, 04:15:47 am »
First of all, how sure are you that you need 1A on the 5v rail? That's unlikely if its only powering the micro and a few leds etc.
If you do need 1A at 5v (note that is 5W) you will have the 7805 burning 7W! as waste heat (12-5*1A) = big heatsink.
In that case you should use a switching regulator - something like a LM2577/LM2673 or any of integrated switch regs. That can be squeezed into about 25x30mm (plus heatsink).
Can you tell us exactly what is powered off the 5v rail (atmega,...,...) ?
« Reply #2 on: April 23, 2018, 10:18:01 am »
Thanks Killcode, Yeah the 1A is a generous calculation.
5V rail powering ATmega328P at 16MHz, 16x2 LCD (approximately 300mA from the datasheet), couple of 3mm LED's(36mA), DHT 11 Sensor(1mA) and supplying the gate for a IRF 540N.
I think I read the ATmega power consumption wrong this morning
Should I still use a switching Reg?
LCD Datasheet:
https://www.engineersgarage.com/sites/default/files/LCD%2016x2.pdf)
Offline Rerouter
« Reply #3 on: April 23, 2018, 10:29:56 am »
Not the cheapest option, But i have been running these in one the worst electrical environment out there without issue (council buses that are regularly jump started and face load dumps)
I used the C series, but you should get by fine with the E Series
C Series https://www.recom-power.com/pdf/Innoline/R-78Cxx-1.0.pdf
E Series https://www.recom-power.com/pdf/Innoline/R-78Exx-1.0.pdf
Depending on your supplier, there about $5 a pop for the E series.
« Reply #4 on: April 23, 2018, 02:20:57 pm »
This looks like exactly what I am after!
Cheers!
