Author Topic: 74HCT74D with feedback in NI multisim  (Read 867 times)
Offline SouthillTopic starter
  • Country: no
    • Photo portifolio
« on: January 12, 2023, 12:20:08 pm »
Hi, im working on a project that needs a flip flop, and the only SOP package avaliable at my school lab is the 74HCT74D. The truth table is not that great for my need, as the D pin needs to be changed between H and L to toggle on the CP pin
In multisim i tried to just connect the Qinverse output to the D pin, and this worked... IN MULTISIM. I have a creeping fear that this wont be the case in real life since states change at the same time.
Does anyone have experience with this, either with the chip or feedback in multisim who can give me some tips ? I know feedback isnt that great to use with latches, but the output in the truth table says Qn+1 so im not sure
There will be a button input to this, so it wont be any high frequency stuff
Also, sorry if this is posted in the wrong place, i am new to the forum
Offline Fgrir
Re: 74HCT74D with feedback in NI multisim
« Reply #1 on: January 12, 2023, 04:18:43 pm »
The feedback on the flip-flop is fine, that is a totally normal thing to do.  What is questionable is the slow edges your input circuit will present to the clock input.  The spec for that chip recommends less than 500ns rise/fall times and you have a 100us time constant filter.  It might work as you have it but to be reliable I would put in a schmitt-trigger buffer to sharpen up the clock input.
Offline themadhippy
« Reply #2 on: January 12, 2023, 04:27:22 pm »
Indeed,its one of those  classic configurations that must stretch back to almost the birth  of logic
Online langwadt
« Reply #3 on: January 12, 2023, 04:32:34 pm »
nothing happens instantly, Q changes (to what D was right before the clock edge) slightly after the clock edge
