Author Topic: ADS layout drawing  (Read 1924 times)
Offline xzswq21Topic starter
ADS layout drawing
« on: February 11, 2018, 11:15:57 am »
Hello
I have designed a 7-th order low pass filter and I drew the schematic in ADS 2016 and simulated it. now I want to transfer it to layout to analysis the PCB layout.
I have found some documents but I haven't been convinced yet :|
from Schematic>Tools>Generate/update Layout>...
How should I select 0603/0402 SMD packaged components?
Thanks
« Last Edit: February 16, 2018, 06:48:18 pm by xzswq21 »
Re: ADS layout drawing
« Reply #1 on: February 16, 2018, 06:47:02 pm »
after some days I could draw the layout but I can't able to find my problem.
I have sent you my project link, please check it and tell me what's my problem :)
Please
http://s9.picofile.com/file/83195811...er1_7zads.html
the Library I have used:
http://s8.picofile.com/file/83195811...2_v01.rar.html
http://s8.picofile.com/file/83195812...brary.zip.html
http://s8.picofile.com/file/83195812...17_10.zip.html
please draw a polygon on the top and buttom layers with 8 mils clearance. (bcoz I have removed the polygon)
Thanks
