Author Topic: Allegro PCB designer : Export PDF  (Read 2463 times)
Offline Thomas83Topic starter
« on: January 23, 2023, 12:56:50 pm »
Hello,
I am using allegro pcb, when I export a pdf file (cf. attached file pdf_publisher), the name of the file is written above (cf. attached file equipement_allegro).
Have any parameters to deactivate this option (write filename to output document)?
Thanks.
Offline Uky
Re: Allegro PCB designer : Export PDF
« Reply #1 on: January 25, 2023, 09:44:44 pm »
I have no answer to your question other than I suggest
that you register with Cadence in order to post this question on their user forum.
There is no need for a valid support account.
You should be able to use the forum regardless if you have it or not.
« Reply #2 on: February 01, 2023, 04:04:56 pm »
Ok thanks.
Offline temperance
« Reply #3 on: February 08, 2023, 06:41:10 pm »
On just enable the "filter header footer" on the PDF export setup tab.
But it seems your version doesn't have this option. In that case I would just set the ext size to 0.001mm so it becomes invisible.
« Last Edit: February 08, 2023, 06:45:33 pm by temperance »
The following users thanked this post: Thomas83
« Reply #4 on: February 09, 2023, 07:53:45 am »
I am using allegro 16.5
I set Texe size for Header/Footer to 0.001mm but the text siez does not change.
« Reply #5 on: February 09, 2023, 07:56:56 am »
Your solution works.
Thanks
« Reply #6 on: February 15, 2023, 12:37:25 pm »
HI everyone,
When I export PDf files, Orcad 16.5 print "target" drawing origin in the pdf (see atached file).
How can I do to export pdf without the target?
Thanks
