Author Topic: Allegro PCB designer : Export PDF  (Read 2130 times)
Offline Thomas83Topic starter
« on: January 23, 2023, 12:56:50 pm »
Hello,
I am using allegro pcb, when I export a pdf file (cf. attached file pdf_publisher), the name of the file is written above (cf. attached file equipement_allegro).
Have any parameters to deactivate this option (write filename to output document)?
Thanks.
Offline Uky
Re: Allegro PCB designer : Export PDF
« Reply #1 on: January 25, 2023, 09:44:44 pm »
I have no answer to your question other than I suggest
that you register with Cadence in order to post this question on their user forum.
There is no need for a valid support account.
You should be able to use the forum regardless if you have it or not.
« Reply #2 on: February 01, 2023, 04:04:56 pm »
Ok thanks.
Offline temperance
« Reply #3 on: February 08, 2023, 06:41:10 pm »
On just enable the "filter header footer" on the PDF export setup tab.
But it seems your version doesn't have this option. In that case I would just set the ext size to 0.001mm so it becomes invisible.
« Last Edit: February 08, 2023, 06:45:33 pm by temperance »
Some species start the day by screaming their lungs out. Something which doesn't make sense at first. But as you get older it all starts to make sense.
The following users thanked this post: Thomas83
« Reply #4 on: February 09, 2023, 07:53:45 am »
I am using allegro 16.5
I set Texe size for Header/Footer to 0.001mm but the text siez does not change.
« Reply #5 on: February 09, 2023, 07:56:56 am »
Your solution works.
Thanks
« Reply #6 on: February 15, 2023, 12:37:25 pm »
HI everyone,
When I export PDf files, Orcad 16.5 print "target" drawing origin in the pdf (see atached file).
How can I do to export pdf without the target?
Thanks
