You’re welcome.
Be aware though, that we are talking marginal differences.
I looked it up in a table and it seems I was wrong on the head height.
ISO 10642 has a 6mm head with 1,2mm height
ISO 7046 has a 5,6mm head with 1,65mm height
Almost every other counter sunk screw falls into the same category as ISO 7046
-> ISO 2009, ISO 15480
Could you elaborate on what the actual problem is with your ISO 10642 hex screws? Maybe there are other means to a solution.
