Author Topic: Altium: Corrupted schematic library  (Read 5230 times)
Offline Mad IDTopic starter
« on: September 01, 2014, 04:48:15 pm »
Hello fellow engineers,
one of my libraries (.SchLib) got somehow corrupted.
The symptom is that I cannot save any changes to it. When I try to save, Altium shows a progress bar on the lower left side and it never ends. If I close the library and open it the new component is not there. I have tried to copy all of the components inside to a new library and the new library is also corrupted.
I see that a temporary file (.$$$) is created and not deleted.
Looks like that some component/components have a faulty binary data in it...?
Any clues on how to fix this annoying issue?
Altium version 13.3.4
Thank you.
Offline Precipice
Re: Altium: Corrupted schematic library
« Reply #1 on: September 02, 2014, 08:11:52 am »
Altium support (or your reseller's support) are where I go for this sort of thing - normally a quick turnaround. This particular problem hasn't happened to me for ages, but I recently had an (imported from PADS) schematic'o'death, which was causing no end of troubles.
Also, of course, you do have decent backups, don't you?
« Last Edit: September 02, 2014, 08:15:15 am by Precipice »
« Reply #2 on: September 03, 2014, 08:29:00 am »
The problem is solved.
There was one corrupted component in a library of 500. We copied chunks of components into a new library until it failed, and then pinpointed one corrupted component which would crash the library.
Thanks for the help.
« Reply #3 on: September 03, 2014, 08:51:28 am »
Glad you cracked it.  :-+
Would you like to edit this thread header to include (solved) for others to find?
The following users thanked this post: mzbas
