Author Topic: Altium Schematic to PDF (component display names mixing up) ?  (Read 1666 times)
Offline SidabrosTopic starter
  • Country: tr
« on: January 08, 2018, 11:42:11 am »
Greetings,
I have an interesting problem that I can not solve. Display names appear normal in schematic design but overlapping when transferred to PDF.
Both Altium library component and my Custom library component that I have made appear strangely when it is transferred to PDF.
Does anybody know how to overcome this issue ?
Best Regards.
« Last Edit: January 08, 2018, 08:51:12 pm by Sidabros »
Offline Chris56000
Re: Altium Schematic to PDF (component display names mixing up) ?
« Reply #1 on: January 11, 2018, 08:05:49 pm »
Hi!
This is a common and annoying bug in Altium I've seen myself - have you tried using a freeware PDF distiller like PDF995 or CutePDF, both of which install as an extra Printing Device, then using the native "Print" option with one of the PDF printers selected?
Chris Williams
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
  • Country: tr
« Reply #2 on: January 12, 2018, 07:47:20 am »
Hey!
Thank you for your response! I will try and share the outcomes of your suggestions later in the afternoon !
Murat.
Offline kristjanbp
  • Country: is
« Reply #3 on: April 03, 2018, 03:41:14 pm »
Hi there.
Did you have any luck? I'm having the same problem and using the method suggsted above is not working.
