i have just created my first, rather complex, custom pattern (Footprint) in Diptrace.
It is a Molex RJ45 Jack. Here is the datasheet, which I also used for all measurements:
https://www.molex.com/pdm_docs/sd/857891001_sd.pdfThe process of creating the pattern was straight-forward, if somewhat tedious. I set the Grid to 0.01 mm and plastered my sheet with measurements
Everything seems to be working out, at least according to the 3D model. After properly offsetting the model, everything fits
I have now a question though that is not specific about Diptrace. I want to know about the required minimum size of annular rings for the two pairs of power pins (P1/P3 and P2/P4 on the datasheet)
Those two pins are only 1.47 mm apart, and therefore do not work with the same ring size of the other pins. Ironically, these are the power pins, which can have almost 60 volts on them at about 500 mA I think.
Currently, I have these set up with 0.95mm hole diameter and 1.2mm pad diameter. With that, the clearance between the pads is just 0.27mm...
Is that still ok? Those seem awfully close together...
Greetings,
Ranayna
