Author Topic: Any fix to EasyEDA bugs?  (Read 1807 times)
Offline ELS122Topic starter
« on: July 29, 2022, 05:45:27 am »
I like easyEDA but its bugs are the worst:
1: while spacing is still set to 10, moving many nets at once often results in many being slightly offset, and thus connecting the 2 together needs annoying 1 spaced offsets in traces.
2: doubled traces/random connections. really often some traces just double up when you move them. and the way the traces move when you move them is unpedictable, sometimes the whole trace moves, sometimes it does what I want: move. but most often it splits into 500 ancors and its just faster to delete it and make a new trace.
3: not really a bug, but when making part layouts/presets it doesnt allow more than one pin to be the same index, but what if you want to have multiple connections to the same pin in the schematic... I dont see why this should be a limitation set in place.
any way to fix these? I somehow doubt professional circuit designers ever use easyEDA for these reasons.
Offline Doctorandus_P
Re: Any fix to EasyEDA bugs?
« Reply #1 on: July 29, 2022, 05:13:53 pm »
Switch to KiCad?
The following users thanked this post: Warhawk, eugene, SiliconWizard, coldfiremc
Offline thm_w
  • Non-expert
« Reply #2 on: July 29, 2022, 08:18:42 pm »
Report the bugs to them, in plain english, with screenshots. Hope they fix it in a reasonable time. If not, move to other software as mentioned.
https://easyeda.com/forum/category/2
Not many professionals would use it, no.
« Reply #3 on: July 29, 2022, 08:20:16 pm »
Switch to KiCad?
I've heard it has the exact same problems.
I don't want to switch since I have a ton of projects and also custom part symbols saved there.
Offline thm_w
  • Non-expert
« Reply #4 on: July 29, 2022, 09:03:31 pm »
Exact same? It has bugs but they are obviously different ones.
https://urish.medium.com/introducing-easyeda-2-kicad-37489da1dfa7
« Reply #5 on: July 30, 2022, 04:17:44 pm »
why would it be so obviously different? if it used the same circuit drawing engine (not clue if it does), it would be quite obvious that it would have the same bugs, naturally.
Offline thm_w
  • Non-expert
« Reply #6 on: August 02, 2022, 09:40:54 pm »
It doesn't use the same circuit drawing engine.
https://en.wikipedia.org/wiki/EasyEDA
Offline rooppoorali
  • Country: bd
« Reply #7 on: September 20, 2022, 03:36:35 pm »
We are free to report but don't know when they will fix.
