Author Topic: Automotive Ethernet and GVIF2 Passthrough PCB Design Discussion  (Read 2779 times)
Offline UnsanityTopic starter
  • Country: jp
« on: December 27, 2023, 05:21:13 am »
Hello,
I am designing a passthrough PCB for Automotive Ethernet and GVIF2 communication lines. The reason why is because the wire-to-wire connectors are not available right now. So, I am making a PCB to connect two harnesses together. The wires of the harness are STP (Shielded Twist Pair), and I would like to continue the continuity of the shield between the harnesses. I assume the cable has an impedance of 100 ohm, but I do not have any specification to back that up.
Each wire has its own shield. I decided to keep each shield plane separate to help prevent noise from traveling between shields. I have stitched the top and bottom layers together to create a cage around the signal traces. No idea if this will actually help, just felt good to do.
If there are general comments, please feel free to share too. I am far from an expert  :P
Sorry if I missed to add any important information needed for an informed discussion.
Question
Is it OK to stitch the top and bottom layer shields together?
Layer Info
Layer 1: Shield
Layer 2: Signal
Layer 3: -
Layer 4: Shield
Stackup Info
See attached images
Inner Copper: 0.5oz
Outer Copper: 1oz
Prepreg Type: 7628
Prepreg Dielectric Constant: 4.4
Differential Pair Design Info
See attached images
ZDiff: 100 ohm (Ethernet and LVDS)
Offline nctnico
Re: Automotive Ethernet and GVIF2 Passthrough PCB Design Discussion
« Reply #1 on: December 29, 2023, 02:31:02 am »
I'd crimp RJ45s on the cable and used a shielded RJ45 to RJ45 coupler.
