Author Topic: Board review request (frequency converter)  (Read 1427 times)
Offline m4rtinpfTopic starter
  • Country: ar
« on: June 29, 2021, 09:39:56 pm »
I've designed a PCB and was looking for some review and advice. The images are attached to this post.
The board is for an up/down frequency converter. Specifically, from 0-300 kHz to 400 MHz.
It's a simple design, the input signal gets multiplied by a 400 MHz square-wave (X1) by a mixer (U6 or U2). There are also two LPF and limiters.
Power comes from a USB connector or a terminal block and gets regulated down to 3.3 V by U5.
I'm planning to get it fabricated by JLCPCB, including the assembly of the SMT parts that they carry. I would have to hand-solder the ICs (or get someone to it). It's a two-layer board, and I need a single unit.
The size of the board is due to the enclosure I'm gonna use (Hammond 1455L801).
I have a few questions:
1. The ground plane is split in two places:
    - The (amplified) clock signal (400 MHz square-wave) from U4 to C3, so VCC can get to the other side of this trace.
    - The down-converted signal (<300 kHz) from U6 to L2, so this trace and the input signal (400 MHz) can cross.
    Is this OK or using 0R resistors would be better?
2. Should I remove the solder paste from the ICs that I'm not getting soldered by JLCPCB?
3. Are the vias connecting the top-layer filled zones to the ground plane enough and well placed (besides the ones under the ICs, just followed the datasheets for those)?
Thanks for any help in advance!
PS: There is a minor misalignment between layers in the images. It's because of a bug in Kicad that makes it so silkscreen is under copper when plotting to PDF, so I had to manually stack the individual layers.
Edit:
I've noticed that some ICs (the ones that I made the footprints for, X1 U3 U4 U7 Q1 U5) have thermal relief ("spokes"), but the rest don't. Should I add it to all of them? Remove it?
« Last Edit: June 30, 2021, 07:38:06 pm by m4rtinpf »
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
Re: Board review request (frequency converter)
« Reply #1 on: July 01, 2021, 06:01:02 am »
You should move this into the projects forum, will get more traction there
The following users thanked this post: m4rtinpf
  • Country: ar
« Reply #2 on: July 02, 2021, 09:10:28 pm »
