Author Topic: changes to design for ESD awareness  (Read 2789 times)
Offline edmundoptTopic starter
  • Country: pt
  • There's theory and practice...
« on: December 12, 2013, 04:15:31 pm »
Hello
I have made a design of a board, this board receives 4 inputs from a 12volts DC power supply connected to microswitches.
Those inputs go through an optocoupler, then through a schmitt inverter and into a 5 volts powered microcontroler.
Those microswitches are far away, 4/5meters and cables go near AC motor.
This PCB is inside a "do not open" metal case connected to mains ground.
I have been reading some documents about ESD, some sugest a ground plane connected with a 2kv CAP, with a .5inches gap between the 12power supply and mains ground, can you guys bring some insight about this.
How can ESD be applied to this PCB, sugestions ?
Offline mike_la_jolla
Re: changes to design for ESD awareness
« Reply #1 on: December 17, 2013, 01:02:37 am »
How are you mounting the PCB in the metal case?  I don't see the holes.
  • Country: pt
« Reply #2 on: December 17, 2013, 10:58:57 am »
At the moment I generated the graphics, the layers were not correct, here is the correct version:
This board is fixed into a DIN rail , with plastic fixing, so there's no grounding of the board.
The question is, should I make a Ground plane near the inputs and connect it through a 2kv cap to mains gnd ?
Or should I leave the board as it is, because it's inside a metal box that is grounded?
Offline JuKu
    • LitePlacer - The Low Cost DIY Pick and Place Machine
« Reply #3 on: December 17, 2013, 12:07:47 pm »
You have optocouplers and if I understood right, the other connections are static. You are set, just don't compromize the isolation barrier. If U1 is the isolator, move D1 further away from the mounting hole.
http://www.liteplacer.com - The Low Cost DIY Pick and Place Machine
  • Country: pt
« Reply #4 on: December 18, 2013, 12:33:27 pm »
ok, so I must respect a gap between the "non isolated" part of pcb, and the isolated part.
the wholes have a plastic tension object to fix, and the board edge is not printed on the PCB. Anyway, I have done some changes concerning your notes.
This is the final version (revised schematic)
« Last Edit: December 18, 2013, 01:20:31 pm by edmundopt »
