Those are net labels, a way of joining 2 or more nets together when placing "wires" around the schematic makes it look messy, also useful since the dawn of multiple sheets / hierarchy as you can have the same nets on different sheets quite easily.
Most if not all packages support this. When it comes to PCB layout all of the nets with the same name are electrically connected and you can see this reflected in the rats nest.
