Author Topic: CL, ZNR, CS as Reference Designators?  (Read 1525 times)
Offline ScutariusTopic starter
« on: June 23, 2022, 01:34:59 pm »
I have a PCB that has some reference designators that I haven't seen before, just out of curiosity, I was wondering if anybody knows what CS stands for
This PCB has
NTCs as "CL", no idea why
MOVs as "ZNR" (I found that ZNR stands for Zinc-Oxide Non-liner Resistor)
but for "CS" I have no clue
it is SOD-123 diode (marking is "AF") but diodes do have "D" as Ref Des in this particular board.
Online T3sl4co1l
    • Seven Transistor Labs
Re: CL, ZNR, CS as Reference Designators?
« Reply #1 on: June 23, 2022, 06:00:47 pm »
CurrentLimiter? Only for inrush, but maybe.  CR (crystal rectifier) common enough for diodes, not sure about CS.
Several have it as a zener: https://smd.yooneed.one/code4146.html
Seven Transistor Labs, LLC
« Reply #2 on: June 24, 2022, 02:47:50 pm »
Thanks, yes, it is most likely a Zener
Sometimes you can tell the region where designers are, earth symbol style on schematic  or selection of negative colors (blue VS black) on equipment
Cheers!
Offline TimFox
« Reply #3 on: June 24, 2022, 04:17:17 pm »
My guess for “CS” is “current source”, a two-terminal device or circuit that maintains a reasonably constant current value over a wide range of voltage across it.  Does that make sense for the overall circuit?
« Reply #4 on: June 24, 2022, 06:04:13 pm »
Not really, it doesn't make sense in once part of the circuit but in other is used as a  flyback diode. (it is actually a bad design overall, some parts doesn't make sense at all)
All ref des start with 0, as R0, D0 etc, and the revision code has a typical SW format, so I assume it most be a software engineer design ...?
« Reply #5 on: July 20, 2022, 08:10:55 pm »
You were right!
https://www.onsemi.com/pdf/datasheet/nsi45030-d.pdf
