Author Topic: connector silkscreen outside of board outline  (Read 2168 times)
Offline Lee LeducTopic starter
« on: August 20, 2016, 09:01:42 pm »
Is having the connector silkscreen outside of board outline an acceptable  design practice? Will this cause a Fab house to reject my Gerbers?
Attached is a board layout used as an example from a PCB layout software package.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: connector silkscreen outside of board outline
« Reply #1 on: August 20, 2016, 09:05:16 pm »
They will truncate this. No issues expected. Have done so a few times.
Offline nctnico
« Reply #2 on: August 20, 2016, 11:39:30 pm »
I never (almost 20 years) had any problem with silkscreen sticking outside the board outline.
Offline sleemanj
  • Professional tightwad.
« Reply #3 on: August 21, 2016, 01:15:46 am »
As above they will crop it.
I do notice however you have what is probably a capacitor top left which is overhanging on what looks to be a screw terminal or something.  Just in case you missed that.
« Reply #4 on: August 21, 2016, 08:53:19 am »
Thanks for the replies. Yes, I noticed the overlapping cap also. The image is from a tutorial that came with the layout software. I used it to illustrate my question (a picture is worth 1000 words).  It's not a board I'm making. Again, thank you everyone for your input.
