So I have a 6 layer PCB:
Used this PCB manufacturer for values.
As you can see, my USB data lines go on 3rd layer from top - "SignalH".
Single strip ought to have 45Ohm, differential - 90 Ohms.
In this website for impedance calculation:
What values do I put in for "H" and small "h"?
I'm guessing small "h" is the distance to closest ground plane, which is 0.2mm in my case? What about big "H"? is it distance from "SignalH" to "Bottom" layer?
Also don't understand why
the same PCB manufacturer has "Symmetric Stripline", when they don't allow for manufacturing in such way.
According to them, signal trace must lie between two ground layers - exactly in the middle, but that's not possible, because they have different thickness for "core" and "prepreg" per
their stackups (see 6 layer, 1mm thickness).
