Author Topic: Convert PCB scan/photo into single colour track diagram?  (Read 2816 times)
Offline Chris56000Topic starter
« on: February 26, 2025, 07:10:48 pm »
. . .Can anyone suggest how I can convert this photo of a Farnell Audio Oscillator PCB into a single plain coloured view of the tracks on a white background please?
. . .I want to convert the tracks to something like solid black svg as I have a Tutorial explaining how to convert the black track artwork into a coloured drawing of the tracks from a friendly Vintage Radio Forum Member!
. . .I want to make the sort of diagram you get in Service Manuals that show the silkscreen and outline in black & the tracks in pink or another colour on a white background!
 . .I am not conversant with image editors by the way!
Chris Williams
« Last Edit: February 26, 2025, 07:27:49 pm by Chris56000 »
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
Re: Convert PCB scan/photo into single colour track diagram?
« Reply #1 on: February 26, 2025, 07:19:19 pm »
. . .This a picture of the copper side of the PCB I want to convert!
Chris Williams
Offline JamesMerry
« Reply #2 on: February 27, 2025, 01:41:07 pm »
Would a contour tool or edge detect in photoshop work?
Ideally you'll get a really clean image with no edge distortion from your camera. Can you place the PCB (gently, so to not scratch the glass) on a flatbed scanner on a printer? Once you have a clean image, any editing tool should be able to fill in the colour differences with whatever you'd like.
« Reply #3 on: February 27, 2025, 06:28:07 pm »
I'm afraid I don't know how to use Photoshop or have a flatbed scanner I can scan the PCB on I'm afraid!
Chris Williams
Online thm_w
  • Non-expert
Online Kean
    • Kean Electronics
« Reply #5 on: February 28, 2025, 04:07:43 am »
I had a quick go with the provided photo in Inkscape, but I couldn't get enough contrast for the trace bitmap function.  There is too much contrast on the solder pads, and not enough between the green shades.  I didn't want to spend more than a couple of minutes trying.
I think to be successful I think you'd need to make another photo with backlighting.
