Author Topic: crowbar circuit OrCAD simulation  (Read 3275 times)
Offline SkylandTopic starter
« on: July 15, 2014, 10:32:44 am »
I have a couple of issues with the simulation;
1. : the zener diode has Vz at 4.7V, it is not behaving as expected since it is reducing the supply voltage by 4.7 instead of setting it to that voltage.
2. : the SCR is not triggering and short circuiting the PSU.
3. : Is there a way to add a spice model to a thermal fuse in capture.
4. : Any recommendations on the values of the resistors and capacitor used?
Offline JacobPilsen
  • Country: cz
Re: crowbar circuit OrCAD simulation
« Reply #1 on: July 17, 2014, 11:06:06 am »
It looks You don't have catode of SCR connected to GND line.
(I don't see the node there.) That line is not straight. Shame OrCad.
In this simulation, there is a probability, that nominal current of Zener is lower that nominal Ig of this SCR. So SCR doesn't have enough triggering current (in simulation).
Offline PedroDaGr8
  • A sociable geek chemist
« Reply #2 on: July 18, 2014, 04:23:17 am »
He's right, look at the cathode line of the SCR there is no pink ball denoting a connection there.
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
