Author Topic: De-Panel Gerber  (Read 589 times)
Offline fossil
  • Country: in
De-Panel Gerber
« on: January 20, 2019, 01:17:25 pm »
I have a set of 9 PCB's in single panel (gerber). I don't need all the PCB's in the panel.
Is there a tool which can help me to separate a PCB from this panel?
Offline Kasper
Re: De-Panel Gerber
« Reply #1 on: January 21, 2019, 07:02:06 am »
You might be able to import gerbers to KiCad pcb design file, delete what you don't want then make new gerbers.
I tried that the other day and the two copper layers did not import properly, luckily the outline did and that was all I wanted to edit anyways.
I might have been doing something wrong, I am not too familiar with KiCad.
Offline fossil
  • Country: in
Re: De-Panel Gerber
« Reply #2 on: January 21, 2019, 08:58:35 am »
"gerbv" allows one to remove elements in gerber. I could do almost everything. I got stuck at soldermask in bottom layer. One can delete elements, but, there is no crop option. Unfortunately, the solder mask is one single polygon.
