I am a novice when it comes to the software tools for PCB design. I would like to create a toner transfer print for a board for which I have a .zip file containing a number of files that the original author says are Gerbers. I found some nice software called GC-Prevue that can load all of the files and I can create a 1:1 print. My question is what are all of the files? They loaded in as Physical Layers in the software. The extensions are .TOP, .SMT, .SMB, .BOT, .SST and .th. I assume .TOP and .BOT are the top and bottom layouts. The .th appears to be a drill hole file, but I can't get that to load except as a layer.
The PCB is not that complicated - 2 layers, with the bottom being entirely ground plane, but it would be nice to know all that I am looking at here!
Thanks
Anthony
