Author Topic: eagle measurement backwards  (Read 1767 times)
Offline willbanksTopic starter
« on: June 24, 2017, 07:13:01 pm »
whenever i try to use the measurment tool in eagle for board design, the numbers are backwards in all directions.
attached picture for example. how can i fix this?
Online jpanhalt
Re: eagle measurement backwards
« Reply #1 on: June 24, 2017, 07:28:35 pm »
Switch to TOP layer (layer 1)
John
Edit: For the measurement, even if item is on bottom
Edit2: Or any layer that is natively top, e.g., info, dimension, and so forth.
« Last Edit: June 24, 2017, 09:11:32 pm by jpanhalt »
The following users thanked this post: willbanks
« Reply #2 on: June 24, 2017, 08:40:22 pm »
thanks!
