Author Topic: Eagle wont let me put vias down while routing a 4 layer board  (Read 1000 times)
Offline ocset
i have a 4 layer pcb that i am routing up.
It has layers (1*2)+(15*16).
When i route on the top and then select the bottom lyaer (16), it gives error "cant set via at -40,30 to layer 16".
It wont let me put vias down.
Do you know why?
Online Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: Eagle wont let me put vias down while routing a 4 layer board
« Reply #1 on: March 21, 2018, 11:47:01 am »
Your layer setup does not allow vias from top to bottom.
You need (1+2*3+16) for that.
Your setup (1*2)+(15*16):
Correct setup (1+2*3+16) without blind vias.
Check eurocircuit drc rules. (attached)
« Last Edit: March 21, 2018, 11:49:10 am by Jeroen3 »
The following users thanked this post: ocset
Offline ocset
« Reply #2 on: March 21, 2018, 11:52:06 am »
Thankyou, you are the Best!
