Hi
What are you trying to do? (what is your application)
Are you making your own boards?
If so, are you etching them or milling them?
If you are not making them, where are you buying them?
What sort of parts do you intend to use?
(What is your assembly process?)
How much do you intend to spend on all this time wise?
What sort of computer hardware do you already have?
How long to you intend to do this? (one project only, or the first of several hundred?)
Lots and lots of details and *many* decisions that all interact.
Bob
At moment, i'm on mac for only search and work, but i want to design project, like motherboards, and other components electronics, and the specs on other computers is good CPU can be good for design PCB's, i want to know what is the best for this kind projects.
Sorry for to much questions, easy way to start this kind projects.
- Anker_by
Hi
If your intent is to design a motherboard, then you probably need to look at professional design packages. Also consider that the first run order on a motherboard is likely to be > $15,000 for the initial half dozen or so boards. That's not including the parts on the boards, just the boards themselves.
Normally board design is somewhere down a road that looks like:
1) Get interested in electronics, read some stuff
2) Decide to buy a board to play with, do some stuff
3) Get some test gear to figure out what went wrong.
4) Need to customize the board, get some assembly tools.
5) Learn some more about what's on the board and how it works
6) Decide that there are simply to many jumpers on the board and look in to alternatives
7) Get some more flexible boards and wire them up
That is about where people then start thinking about board design.
Bob
