Author Topic: EasyEDA - How to draw diagonal (or any angle) wire/net on schematic?  (Read 2374 times)
Offline dmm2018Topic starter
  • Country: my
Hello...
A figure (see below) in the EasyEDA tutorial (https://easyeda.com/Doc/Tutorial/Doc/EasyEDA_Tutorial_20170920.pdf) shows that diagonal (or any angle) wire/net can be drawn on the schematic. I have gone through the tutorial but could find a way to draw diagonal wire/net. Please share if you know how to draw diagonal wire/net on EasyEDA schematic.
Thanks
Offline 3dgeo
Re: EasyEDA - How to draw diagonal (or any angle) wire/net on schematic?
« Reply #1 on: February 13, 2019, 01:09:56 pm »
Hello,
I believe (not totally sure) You can't draw angled net lines, but You can move points after you draw net line and make them any angle You want.
By the way, EasyEDA has it's own support forum.
