hi,
what ETA do you negotiate for successful prototype starting from scratch (what the un-informed client wants) for a medium-complex pcb (like 120x80mm, including 3-4 input modular sensors incorporated on-board, microcontroler core, 2-3 dcdc's, some opto isolators)? the pcb's will be done with eurocircuits for example, i like them.
the expected bom is like 50-70 components for the simpler one and will go upto maybe 100-120 for a more complex pcb i'll need to design.
the further assembly is not my concern, of course i'll keep in touch with assembly line technician in order to use components he can easily mount in some chinese smt line (qm61 or smt660/880 pnp machines)
where i worked, projects(boards) like this took sometimes 2-3 months to be up-and-running 100%, firmware included of course, with all client hw/sw validations passed correctly and some bigger/more complex pcb's even more
why i ask? because i may accept a pcb designer position and the last time i did this type of work was in 2016-2017, maybe some things are changed. i designed only 3 boards before (same complexity, microcontroller with oled/optos/optotriac/dcdc's switching type, size 85*60 for example). and this type of job is my dream-job and i wanna do it by the book, if this still exists those days.
regards,
pierre
