Author Topic: Finding a local engineer / firm?  (Read 2896 times)
Offline SteveWTopic starter
« on: September 20, 2013, 02:43:56 pm »
Hi!
I'm primarily a software guy, but I've built a "proof of concept" device that solves a problem for the business I work for. We are looking to take the project to the next step, and need someone who actually does this stuff for a living to design the product professionally (enclosure, pcb, component selection, etc).
This brings me to my question;
What, generally, is the best way to find and hire an engineering firm?
Should we look locally, or is a remote firm just as good?
How should we vet the firm?
What are reasonable fee structures? Is this primarily a per-project or per-hour affair? If per-hour, what's a decent "going rate" ballpark?
What aren't I thinking about?
Cheers,
Steve
Offline notsob
Re: Finding a local engineer / firm?
« Reply #1 on: September 20, 2013, 11:53:31 pm »
It would help if we knew where you are, why not change your profile to show what country you are from
Offline nctnico
« Reply #2 on: September 22, 2013, 12:04:54 am »
It depends a bit on what you want. Some of my customers want a complete (tested & packaged) product they can sell from their webshop while others just want the design files and deal with the production themselves.
Vetting a company can be tricky but since you already made a prototype you should be able to seperate bullshit from good advice. Google and Linkedin may help to get an idea of someone or a company.  If your own design is mostly production ready then it shouldn't take much time to turn it into a product. OTOH don't be afraid if someone wants to redesign the whole thing to make it easier (cheaper) produce. Just make sure whether the extra time is really worth it.
What helps is to set a realistic budget and divide the project into smaller sub-projects with milestones. The next thing you need is a good specification with quantifiable project goals. This way you can keep track of progress, meeting project goals and the amount of money being spend.
Offline IanB
« Reply #3 on: September 22, 2013, 12:28:37 am »
The key question from your post that is not answered clearly is this: design, or make?
If you want someone to do a design for you, then you would need to engage a consultant. To locate a good consultant you will need professional recommendations.
On the other hand, if you have a design and you want someone to make it for you (how many, by the way?), then you need a manufacturer. The manufacturer may have in-house design services to help refine the design for manufacturing, or they may not. You need to be very clear about what services you need.
In general, if you want someone to make something for you, you would put together a specification, send it to a shortlist of potential vendors and invite proposals. Then you would go through each proposal and make a list of questions needing clarification to help you make a final choice. You may want to consider referrals or testimonials to help you decide, such as through a BBB.
Offline AndyC_772
« Reply #4 on: September 22, 2013, 10:28:08 am »
Word of mouth recommendation is best, IMHO. If you don't know anyone who has this experience, then I'd suggest looking for someone whose customers are like you in terms of size and in the nature of the work they're looking for (ie. design, manufacture, documentation, prototypes, manufacturing, service etc).
Reasonably local is good, you want to be able to meet face to face at least occasionally. At the very least, you're likely to want an initial kick-off meeting where you can show the engineer what you've already done and explain what you're looking for as a next step. Beyond that, phone calls and email seem to work pretty well.
Make sure you meet the engineer who will be working on your project in person. Do they seem knowledgeable, familiar with your type of business, and able to make helpful suggestions from an early stage? Do they obviously, clearly understand what it is you're looking for?
By all means ask for references, though bear in mind that in many cases, confidentiality agreements will mean they can't give you the names of other customers. They might be able to put you in touch with their own suppliers or service providers, though, who will be able to give you an idea of what they're like to deal with, and whether their designs tend to be right 1st time or whether they go through many revisions before never hitting production.
The better idea you're able to give an engineer what it is you need, the more likely you are to be able to get a firm quote. If you can provide a detailed technical specification, list of requirements, some design acceptance criteria and a list of the documentation you require - and you promise not to change your mind! - then you may be able to get a firm, fixed price quote. If you can't provide those things, expect to pay an hourly rate, because the engineer has no way to know upfront how much work is involved, particularly if you haven't worked together before.
Without a detailed spec you should still be able to get an estimate, but bear in mind that it will have to be a bit flexible. The most important thing if you want to keep control of costs is to work out as early as you can what the final spec needs to be, and then not to change your mind halfway through. It's very rare indeed that a design can be modified part way through to "just add..." something without there being a knock-on effect and a price increase.
You're asking the right questions, no problem there. The main thing to invest some time and effort in, is defining the project as completely as you can: inputs, outputs, how big can the board be, where does it get its power from, how many will you be building, who will use / test / install / maintain it, what regulatory approvals does it need and so on. A good engineer will help you answer these if you need it.
