Author Topic: Flexible polyimide PCBs  (Read 2182 times)
Offline LukeWTopic starter
« on: December 17, 2016, 08:59:13 am »
I'm looking for some board fab in flexible polyimide.
Small batch of about 10 boards for prototyping, or even just a few, depending on the economics.
135 x 17mm dimensions.
2 layer copper, and "typical" cheap design rules, i.e. 6/6 with 13 thou smallest drills.
Can anyone recommend a cheap place?
Re: Flexible polyimide PCBs
« Reply #1 on: January 11, 2017, 07:13:04 pm »
I need a flexible PCB in 135mm x 17mm, and Seeed apparently only supports a width up to 100mm.
(2-layer needed, and nothing really tight in design rules.)
Any other recommendations?
Offline miceuz
  • Country: lt
    • chirp - a soil moisture meter / plant watering alarm
« Reply #2 on: January 12, 2017, 03:45:36 pm »
Try Elecrow. I was quoting them for custom PCBs recently, I'm not sure, but I think they have a custom size flex PCB service.
Offline technotronix
    • PCB Assembly
« Reply #3 on: January 20, 2017, 12:44:25 pm »
