SOLVEDHi everyone,
I need to simulate a sensor noise floor for which I have the curve, to do this I wanted to create a couple of noise sources that would give me flicker noise and white noise, Section 4-5 in this book:
https://pearl-hifi.com/06_Lit_Archive/14_Books_Tech_Papers/Motchenbacher_Connelly/Low-noise_Electronic_Design.pdf suggested biasing a diode with a DC current source to generate some 1/f current noise, then measuring this current noise with a dummy 0V voltage source (with a 1GF cap decoupling I_DC) and finally using the dummy VS to drive a current dependent voltage source to turn it into voltage. From there it would only be a matter of fitting the Diode variables KF and AF to get the expected level.
However when I perform the .noise analysis all I'm getting is a constant noise spectra fixed at 3.12pV/Hz½, no presence of flicker noise no matter how much I play with the parameters...
FlickerVoltageNoise_Motchenbacher.asc (0.82 kB - downloaded 1008 times.)
I've been at this all day and I cannot get it to work, I tried with a noiseless series resistance to the diode but that gave me a constant 0pV/Hz½. how can I get this to work? Is there some workaround to get a flicker noise voltage in LT-SPICE?
You can find the simulation file "FlickerVoltageNoise_Motchenbacher.asc" in up this post.
Many thanks in advanced.
Guille
