OK, I'm confused. I want to use a Bourns CM filter from digikey:
https://www.digikey.com/product-detail/en/bourns-inc/SRF2012-361YA/SRF2012-361YACT-ND/2681277Firstly, the 3D render on Digikey is just... wrong. I hope. I mean, I'd rather not have the wires attached to the pad like that...
But OK, it's just a picture. As it's been a while, I figured perhaps the Ultra Librarian thing might be worth another shot.
So, no. Really, no. I'll just roll my own, thanks. When I added the .step file, it looked something like this:
Note how a large part of the component pad is not on the actual footprint. So, I obviously figured I got the dimensions wrong (added the pad sizes):
So, umh, how is a 0.46mm component pad supposed to fit on a 0.4mm footprint pad? That's even a bit out of center? The horizontal size is actually large enough but so badly off center the component is once again not on the pad. Leaving it like this is not an option as I assume the height of the solder mask will make for either the soldering to be bad or the component to rotate, or...
So I guess I'll just enlarge the pads and hope for the surface tension to get it right, but seriously... WTF??
