Author Topic: Free screen recorder for Teams tutorials on PADS  (Read 1396 times)
Offline FaringdonTopic starter
« on: June 22, 2021, 04:58:33 pm »
Do you know of any safe to download, free screen recorders for use recording Teams tutorials on PADs?
Or if none free, which is the best value for money and safe to buy?
I have bandicam, but its only for 10mins recording. Also Debut, but its also similarly limited.
'Perfection' is the enemy of 'perfectly satisfactory'
Offline PlainName
  • Country: va
Re: Free screen recorder for Teams tutorials on PADS
« Reply #1 on: June 22, 2021, 05:59:50 pm »
Would OBS Studio be suitable?
https://obsproject.com/
The following users thanked this post: Faringdon
« Reply #2 on: June 27, 2021, 03:08:52 pm »
Thanks, i ended up using zoom, and setting up a meeting with myself, then clicking "share" and also clicking "share audio".
I play it back with VLC media, because then i can  speed up to get through the not needed bits.
Its a nuisance in VLC media to speed  though up because theres no shortcut key for it.
Offline PlainName
  • Country: va
« Reply #3 on: June 27, 2021, 03:20:38 pm »
Great bit of lateral thinking  :-+
Offline Mark
« Reply #4 on: July 02, 2021, 10:05:23 am »
In VLC, use the square bracket keys:
] for 10% faster
] for slower.
Offline mariush
« Reply #5 on: July 02, 2021, 10:10:50 am »
Virtualdub can also do screen capture and audio capture : https://sourceforge.net/projects/vdfiltermod/
Not as friendly UI as OBS but straight out the box has potential to produce higher quality capture as you can use lossless codecs for the initial capture, like MagicYUV for example.
You can tweak the x264 settins in OBS for near lossless by entering command line parameters ex --qp 5 --tune stillimage for example but you still get a lossy mp4/mkv file
There's a capture menu, you have to set the destination file , them set capture source , codec to compress with, then select audio source, codec to compress audio with (can leave uncompressed audio but will use space) and then you can capture to your heart's desire.
