Author Topic: Free STEP viewer?  (Read 40468 times)
Offline DutchGertTopic starter
Free STEP viewer?
« on: October 19, 2016, 04:27:10 pm »
Hi guys,
Does anyone know a good, free, offline STEP viewer?
I tried STP Viewer (http://stpviewer.com/) but it does not seem to support colors in the STEP files.
Also, FreeCAD seems very slow....
Offline John Coloccia
Re: Free STEP viewer?
« Reply #1 on: October 19, 2016, 04:37:06 pm »
I use STPViewer to double check my CAD exports before sending off to the machine shop. I didn't know you could even store color information in STP files.  What are you trying to view?
Offline HighVoltage
« Reply #2 on: October 19, 2016, 04:45:47 pm »
I am using the e-drawings feature of Solidworks.
There is a free version available but that one may not open STP files, I am not sure.
There is also 3D-Viewers, but I am not sure what the free version is limited to.
http://3d-viewers.com/
« Reply #3 on: October 21, 2016, 10:17:05 am »
Yes you can, I want to use it to check my 3D output version of the PCB form Altium Designer
Offline sleemanj
  • Professional tightwad.
« Reply #4 on: October 21, 2016, 10:53:23 am »
Autodesk 123D can import step I think.
Offline blackfin76
« Reply #5 on: October 21, 2016, 11:18:11 am »
I use IDA step viewer
http://www.ida-step.net/
Offline Karel
« Reply #6 on: October 21, 2016, 12:58:51 pm »
Offline Smokey
  • Not An Expert
« Reply #7 on: October 31, 2016, 07:05:16 pm »
Topic: Free 3D model STEP file viewer I can recommend to customers...
https://www.eevblog.com/forum/projects/free-3d-model-step-file-viewer-i-can-recomend-to-customers/
Offline gkv311
« Reply #8 on: January 16, 2017, 08:35:25 pm »
You can try CAD Assistant - free for OS X, Windows, Android and iOS.
Supports viewing and converting plenty of formats including STEP with colors:
https://www.opencascade.com/content/cad-assistant
Offline daqq
  • Country: sk
    • My site
« Reply #9 on: January 20, 2017, 08:54:14 am »
Varicad viewer can handle STEP files:
https://www.varicad.com/en/home/products/products/
Offline julianhigginson
« Reply #10 on: January 23, 2017, 11:03:57 am »
you are using Altium? how about export a 3D PDF?
Offline Smokey
  • Not An Expert
Offline dalescott
« Reply #12 on: January 09, 2019, 08:54:55 pm »
The current eDrawings reads STEP files and is simple! I have a STEP file for an embedded product (10 top-level product, 60 parts each in a 5-deep hierarchy with re-use of major electronics sub-assemblies). I'm reviewing the design and stepping through the hierarchy. How best to select and hide, or hide others, took some getting used to (and I still don't seem to understand correctly). You can also apparently markup a drawing (possibly to send back to the designer for another iteration) but I haven't tried.
First time poster, long time listener (thanks Dave!).
Dale
« Last Edit: January 09, 2019, 09:30:00 pm by dalescott »
Offline HighVoltage
« Reply #13 on: January 10, 2019, 11:41:31 am »
Welcome to the forum.
Yes, the eDrawings indeed opens STEP files perfectly.
I just got a huge 165 MB STEP file from a customer, the largest file I got so far.
It opens in eDrawings right away within seconds.
But in Solidworks it needs about 5 min, to analyze all details, before it opens up.
Offline SiliconWizard
« Reply #14 on: January 10, 2019, 04:38:59 pm »
I use FreeCAD as well.
Note of caution: it doesn't have the most intuitive workflow. You have been warned. ::)
Offline xzswq21
« Reply #15 on: February 07, 2019, 07:49:38 am »
use 3D-tool. the best tools to see 3D files :) very simple and fast
https://www.3d-tool.com/
message me if u want to check it, I can send u.
Offline christinarebel
« Reply #16 on: May 01, 2019, 04:19:22 pm »
On Wikifactory, you can view STEP files and a whole range of CAD formats without needing plugins or installs: https://wikifactory.com/
Take a look at this VR headset to see how it is viewable even on Mobile: https://wikifactory.com/+wikifactory/north-star-build/file/Assembly/LMC.step
We breakdown the feature here: https://wikifactory.com/+wikifactory/stories/introducing-our-brand-new-file-visualisation-system
Disclaimer: I am Wikifactory Co-founder  :)
Offline emsnickw
« Reply #17 on: March 09, 2020, 01:54:27 am »
I found this recently. Works in your browser and no login required.  :-+ :-+
https://www.emachineshop.com/free-online-step-file-viewer/
Offline Feynman
« Reply #18 on: March 10, 2020, 07:03:00 pm »
I use Design Spark Mechanical for this purpose.
Offline GloW
« Reply #19 on: December 15, 2021, 11:44:19 pm »
You can use F3D to quickly view step files !
f3d-app.github.io/f3d/
disclaimer: I am a F3D dev
Offline rpiloverbd
  • Country: bd
« Reply #20 on: December 20, 2021, 11:26:57 am »
Here you can find various ways of opening a PCB file using offline software like Eagle, Altium etc.: https://www.raypcb.com/open-pcb-files/
Online nctnico
« Reply #21 on: December 21, 2021, 07:23:58 pm »
Looks interesting.. just a question: can it also export step files? What I'm looking for is a tool which can compress / optimise STEP files. The PCB package I'm using produces massive STEP files which IMHO can be significantly optimised.
Offline PlainName
  • Country: va
« Reply #22 on: December 24, 2021, 08:41:08 am »
Pains me to say it but I think Fusion360 will import .stp (in fact, I know it will) and re-save as optimised. But the person to ask, to be sure, is beanflying who often regales us with his enjoyment of it and its capabilities.
Offline Bassman59
  • Yes, I do this for a living
« Reply #23 on: December 29, 2021, 08:04:17 pm »
Fusion360 absolutely imports STP -- I use that feature all the time, as PCB layout programs export in STP.
Once the model is in F360 I don't particularly care what the program does with it.
Offline Hawaka
« Reply #24 on: November 29, 2023, 06:36:20 pm »
If anyone stubble on this thread I just found Mayo as a great stp viewer because of the following:
- Color support
- Dimensional measurement
- offline, no subscription
- fast and light
https://github.com/fougue/mayo
The following users thanked this post: spostma
