FreeCAD has been working great for me since .016
I figured I'd post a few pictures of a bigger assembly, and other MISC BS currently being worked on. All this talk of Fusion360.. BLAH! Subscription base software = GARBAGE, two thumbs down in my opinion. I think it all boils down to a learning curve. No matter the software... This would be like comparing GIMP to Photoshop... Both do EXCELLENT jobs, albeit one a bit harder to work with then the other, all to accomplish the same if not identical results as the other. Call it as you will... You can say to same for the IDE's and EDA's. I'm sure in the end, the story will tell itself. THE PRODUCT...
All I can say is, DO NOT, I repeat, DO NOT be afraid of FreeCAD, it truly does GREAT work!. Honestly, I wouldn't use anything else myself. But hell, I guess FreeCAD just works for me, and I'm partial to open-source.
I figured I'd post on this FreeCAD topic to start my 'first EEvBlog post', I know a bit old... Sorry if that goes against the rules. I just figured someone should advocate for FreeCAD in bigger sense. If you can get past the 'FREE' isn't as good as 'PAID FOR' mindset. Then you, and only 'YOU' will be liberated. Good Luck!
Some PCB's and Case's for those PCB's, all done in FreeCAD. and it generates G-CODE, which also work's great in the CNC...
