Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Gold plating through holes and vias.
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Gold plating through holes and vias. (Read 1711 times)
semir-t
Regular Contributor
Country:
on:
November 06, 2018, 10:23:34 am »
I have a question and I can't seem to find an answer.
When the PCB is gold plated is the inside of the hole plated to. By looking at the pictures of some boards I can see that there seems to be gold, but I don't know if that is general rule or it should be payed extra to manufacturer.
Logged
Niklas
Frequent Contributor
Country:
Re: Gold plating through holes and vias.
Reply #1 on:
November 06, 2018, 07:10:44 pm »
The gold coating covers all the exposed areas, so if the via holes are not covered with solder mask they will also get gold plating. However, the thickness might not be the same inside the via holas as on the solder pads.
Logged
semir-t
GeoffreyF
Regular Contributor
Country:
Reply #2 on:
November 06, 2018, 08:56:10 pm »
If the hole is big enough to get wet, it will be plated. The metal is carried as atoms through an electrical field in a solvent. The holes are plated through before the board is etched into circuit patterns.
Logged
US Amateur Extra W1GCF.
semir-t
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
