yeah I have a tag connect cable already.. used it once where I had a board that didn't have the space for a header, thanks to a low profile custom case... But I prefer cortex-debug header normally it's a lot more straightforward.
Also, yeah testpoints for production will be spaced properly for bed of nails... I can do that. This version of the board is gong to be more for development/prototyping, but I will try to do test points for Pogo pins on the breakaway tab just in case it's perfect and can become full production.. :-)
Thanks for the idea of narrowing down the traces at the intended break.. I was worrying about the copper not breaking, and ripping off the board. though would be cutting the mousebite, so probably not likely unless someone tried doing it by hand.
