Reject the batch.
What's happened is that their transparencies have become contaminated, with the result that each board has track damage in the same place. They've attempted a repair - and sometimes these are acceptable - but they've not done a good job. Long term reliability is not guaranteed.
I sometimes tell a cautionary tale of the time this happened to a board I designed some years ago. They were made 4 boards to a panel, and almost 25% of them had a failed trace in exactly the same place.
What had happened was a tiny scratch on the artwork, so every board which was made in that position in the panel had a fault as a result.
This wouldn't have been so bad, except for the fact that we'd paid for bare board test, and had therefore assumed the boards we received were OK to use. So we did, and only found the fault once the boards were populated. Thousands of pounds' worth of brand new kit had to be scrapped.
We gave the PCB vendor hell, of course. The test operator's response? "I saw so many failures in the same place that I thought it was a fault with the test equipment, so I just let them all through anyway".
I think he lost his job over that one.
