Author Topic: Header pin hole diameter  (Read 19999 times)
Offline headingwestTopic starter
« on: May 22, 2013, 04:35:22 am »
Hi All, I'm putting together my first PCB.
At one edge are some header pins. I've downloaded a number of datasheets but can seem to get a standardised hole diameter that would work well.
Does anyone have an opinion on a good generic hole size for these connectors?
Thanks.
Offline mariush
Re: Header pin hole diameter
« Reply #1 on: May 22, 2013, 05:18:37 am »
If you mean the standard 2.54 mm (0.1") spaced pin header, seems that diameters range between 1 and 1.15 plus some tolerance.
Ex see
http://www.farnell.com/datasheets/1670824.pdf
http://www.farnell.com/datasheets/1442180.pdf
http://www.farnell.com/datasheets/819778.pdf
http://www.harwin.com/include/downloads/drawings/M20-995.PDF
So use whatever's standard above 1.1mm or so?
Offline poorchava
  • Troll Cave Electronics!
« Reply #2 on: May 22, 2013, 11:32:26 am »
I use 0.9 for a loose fit and 0.8 for tight fit.
Offline free_electron
    • SiliconValleyGarage
« Reply #3 on: May 22, 2013, 02:53:58 pm »
45 mils hole works well.
Offline cthree
« Reply #4 on: May 28, 2013, 04:55:36 pm »
I use 40mil which is nominal I thinks.
