Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Help finding the right WiFi antenna & connector for data logger
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Help finding the right WiFi antenna & connector for data logger (Read 2307 times)
Martin F
Regular Contributor
Country:
on:
May 15, 2018, 08:30:01 pm »
Hi there,
We're developing a small data logger where we need to add an external WiFi antenna.
The enclosure is as in attached PDF drawing and we need the antenna to go out of the Ø6.50 hole on page 5/5.
We've looked at the following that matches our technical specs, but not the size:
Connector:
https://www.mouser.dk/ProductDetail/taoglas/cab721/?qs=%2fv8iy7V9uix41yCF2gxgAA==&countrycode=DK¤cycode=DKK
Antenna (Small):
https://www.mouser.dk/ProductDetail/linx-technologies/ant-24-cw-rh-sma/?qs=K5ta8V%252bWhtZm2nPYHBDdAg==&countrycode=DK¤cycode=DKK
Antenna (Large):
https://www.mouser.dk/ProductDetail/microchip/rn-sma-4/?qs=3vk7fz9CmNwM0uJP168ecg==&countrycode=DK¤cycode=DKK
A few pain points with above that we're trying to solve:
1) The connector has a very long screw head, which means the antennas we can find leave a lot open (as the width of the end cap is only 1.5mm)
We'd ideally want something that could avoid this problem.
2) The wire that goes inside the enclosure from the connector is very long - we'd prefer something shorter
3) The Antenna (Small) is unable to bend, which makes it less ideal for packaging etc.
4) The Antenna (Large) is too large and exceeds the width of the product
5) The outlined examples are all quite expensive - we're interested in a cheaper solution if one exists
We'd ideally like an antenna that can "bend" (ideally in all directions), but which is close to the size of the Antenna (Small).
And ideally a connector that fits the antenna in our enclosure with only a 1.5mm end plate.
We're rookies when it comes to WiFi antennas, so we'd love to hear any tips/ideas for this.
Thanks a ton!
Martin
Logged
stevelup
Regular Contributor
Country:
Re: Help finding the right WiFi antenna & connector for data logger
Reply #1 on:
May 17, 2018, 06:30:06 am »
Search for 'stub' or 'stubby' antennas - that's what you want for this in my opinion.
If the SMA connector is protruding too far through your case, just put a spacer on the inside?
Mouser is an expensive place to buy this stuff - depending on volumes, you'd be better off getting it from China.
Logged
Martin F
Regular Contributor
Country:
Reply #2 on:
May 17, 2018, 06:33:36 am »
Thanks for the tip - any Chinese retailers you can recommend ?
Logged
stevelup
Regular Contributor
Country:
Reply #3 on:
May 17, 2018, 06:40:43 am »
I'd start with AliExpress
35mm stub antenna:-
https://www.aliexpress.com/item/small-size-WiFi-Antenna-rubber-antenna-short-2-4GHz-Antenna-stubby-antenna-Zigbee-Antenna-RP-SMA/32827467388.html
You can get the pigtails from there for about 7 NOK
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
