Author Topic: Help with designing a controlled impedance flex ribbon  (Read 440 times)
Offline nergalTopic starter
« on: March 30, 2025, 10:10:17 am »
Hello all,
Anyone willing to help out a fellow EE. I am designing a dual layer straight flex ribbon cable to pass 4x PCIe signals between two boards and I am having issues with the GND cross hatching pattern.
Can anyone with access to Simbeor make a small calculation for me and post the dimensions of the hatch pattern? Software like this is expensive and was not able to find a free version.
Target impedance is 100ohm for differential traces. And the stackup is the default jlcpcb dual layer flex. The ribbon is straight 15cm, no bends or anything. I can give you the Kicad brd file if that helps.
Any help is higly appreciated.
Offline nctnico
Re: Help with designing a controlled impedance flex ribbon
« Reply #1 on: March 30, 2025, 12:26:57 pm »
You might be able to simulate with a free version of Sonnet (Sonnet Lite) but I don't know if they still have free version available.
« Reply #2 on: April 04, 2025, 02:27:59 pm »
Thank you for the reply. I tried Sonnet Lite but unfortunately I cannot upload the Gerber files as that feature is not available on the Lite version. Either I am not using it correctly or the Lite version is not meant to do this.:(
Offline nctnico
« Reply #3 on: April 09, 2025, 08:58:22 am »
You don't upload the gerber files. Simulation would take too long anyway. Instead you draw a portion of the flex pcb and simulate that to check whether you get the widths and height correct.
