Author Topic: Help with gerber file format please  (Read 1764 times)
Offline boylesgTopic starter
« on: November 07, 2018, 11:25:38 am »
Question for anyone familiar with PCB design and Gerber file format.
I have been reading this document but unfortunately it contains too much engineering gibberish and not enough simple explanation
X-2794000Y-254000D2*
D14*
Y-508000D1*
X-2286000Y-762000D2*
X-2540000D1*
X-2794000D1*
It seems obvious the the X and Y denote the x and/or y coordinates of a point in a polyline.
And the D1 and D2 denote move to and llne to commands
But hat are the units here? Are those integers referring to steps (as in a stepper motor) or millimeters or something else?
But I can't figure out what all of this means.
%TF.GenerationSoftware,Novarm,DipTrace,3.2.0.1*%  // This is just the software that generated the gerber file
%TF.CreationDate,2018-11-07T12:25:27+09:00*%     // And the file date....all good
%FSLAX35Y35*%                                                           // What is this?
%MOMM*%        // What is this?
%TF.FileFunction,Copper,L2,Bot*%                                // Copper clad board but what do L2 and Bot mean?
%TF.Part,Single*%                                                         // Single sided PCB....all good
%TA.AperFunction,Conductor*%                                    //
%ADD14C,2.0*%                                                            // What do these two lines mean?
%TA.AperFunction,ComponentPad*%                            // Get this....all good
%ADD15C,2.3*%                                                            // My pads in diptrace were circles of 2.3mm diameter.....all good
Offline ataradov
    • Personal site
Re: Help with gerber file format please
« Reply #1 on: November 07, 2018, 05:34:08 pm »
Gerber files are described by the standard RS-274X. Here is the document: http://www.apcircuits.com/Portals/0/Assets/Downloads/the_gerber_file_format_specification.pdf?ver=2015-06-13-175030-363
"%MOMM*%" - this sets the units to millimeters. "%MOIN*%" would be inches.
Alex
Offline SiliconWizard
« Reply #2 on: November 07, 2018, 07:15:39 pm »
Those are the two function codes that define how coordinates are to be interpreted in a Gerber file.
MOMM => coordinates are in mm
FSLAX35Y35 =>  omit leading zeroes, absolute, X and Y coordinates in 3.5 format (meaning 3 integer digits and 5 decimal digits)
Strongly suggest you read the spec. doc as ataradov pointed you to.
I'll give you the official Ucamco page though: https://www.ucamco.com/en/file-formats/gerber/downloads
