Is that not FR-4? e_r is usually 4.2-4.8, and higher for prepreg than core material.
IIRC, 1.8V LPCMOS is intended for low power, and is a little different from SSTL, and using the SDRAM controller (at least) required an extra license..
whereas the SSTL version didn't...
Length is not a parameter in the characteristic impedance of a transmission line, only the cross section matters. Read up on transmission lines!
The short of it is, a true electrical delay looks like series inductance or parallel capacitance at low frequencies (indeed, most of the time this is what real capacitors and inductors are composed of), but the impedance becomes complicated at frequencies having a wavelength near the electrical length of the transmission line. When the line is properly terminated at one end, it looks like a perfect resistor at the other end; at other matches, the impedance is reflected or transformed, depending on length and mismatch.
If you think about impedance, versus time rather than frequency, then a transmission line looks like its characteristic impedance until a reflection comes back. A pin driving the trace from the end, with source matching (typical for CMOS pin drivers), makes a voltage divider of equal resistances, and therefore the pulse (as seen at the source) has a flat spot at VDD/2 for twice the line length. When the wave reflects off the end and comes back (hence twice the delay), if it's the same amplitude (i.e., wasn't terminated at the load end), it adds to the existing voltage (superposition), and stabilizes at VDD. If the load end is terminated, then no wave comes back, and it stabilizes at VDD/2 at both ends (which is what you expect at DC, because it has source and load resistors which act as dividers). Or you can use a low impedance unmatched source and a matched load, in which case the steady voltage is a little less than VDD.
For a source in the middle of the line, the two halves of the line act in parallel, and the source initially sees half Zo. When the nearer (stub) reflection comes back, it reinforces the source and it acts like a regular (end) driver. It's not possible to have full CMOS logic levels, and have sources connected this way, because CMOS pin drivers cannot deliver full VDD/GND to such a low impedance. This is basically why SSTL exists: a small, well defined logic threshold around VREF (which is held near VDD/2), and using source and load termination resistors (which still can't prevent stub loading effects -- indeed, all sources and loads see Zo/2 -- but do prevent reflections, so signal quality is still good).
Needless to say, to verify the signal quality, you need an oscilloscope with bandwidth that includes the electrical length of the traces, and the edge speed of the devices. Which I guess is several GHz in this case. And you need probes and testpoints capable of connecting to it with similar fidelity.
