Author Topic: How long can I leave paste before ovening  (Read 1977 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: July 25, 2018, 10:41:36 am »
I am placing a board and have found one part to be the wrong package. Can I leave in 24 hours until the replacements arrive or should I reflow now and then try to rework the parts in?
Online mikeselectricstuff
    • Mike's Electric Stuff
Re: How long can I leave paste before ovening
« Reply #1 on: July 25, 2018, 10:44:10 am »
Look at the paste datasheet, it will usually spec the working life. ISTR 24hrs is typical, but keep it cool.
Day Job: Mostly LEDs
  • Global Moderator
« Reply #2 on: July 25, 2018, 11:05:58 am »
  • Global Moderator
« Reply #3 on: July 25, 2018, 01:14:48 pm »
Parts are on order and the boards are in the fridge with all parts but the missing ones.
Offline wraper
  • Country: lv
« Reply #4 on: July 25, 2018, 01:28:03 pm »
Depends on the solder paste. For example I left GC10 for 3-4 days and it still was tacky and reflowed without noticeable issues. On the other hand some other pastes become dry and non sucky in a few hours.
Offline wraper
  • Country: lv
« Reply #5 on: July 25, 2018, 01:34:49 pm »
Leave them at room temperature for at least a few hours before reflowing to avoid issues with moisture.
http://www.indium.com/blog/humidity-and-solder-paste-do-not-mix.php
  • Global Moderator
« Reply #6 on: July 25, 2018, 02:05:01 pm »
OK will do, fortunately this is all in the office and humidity is at 37% in the room. I'll also do a prolonged warm up in the oven, do a spot of 50-80C before bringing to 100 and then the reflow temperature.
« Reply #7 on: July 25, 2018, 03:07:26 pm »
I think the main concern is screen life, once printed, the flux is still there even if the solvent has evapotared
Offline wraper
  • Country: lv
« Reply #8 on: July 25, 2018, 03:25:31 pm »
Once solder paste is no longer tacky, you will have tombstoning problem or parts could even move off from the pads completely.
