Author Topic: How to auto connect power traces from Schematic to PCB in Diptrace  (Read 2945 times)
Offline abdullahsebaTopic starter
Hi
I'm not sure of the correct terms but when I add the ground and 5v symbol in my schematic  in two different places than convert my schematic to a PCB they are not connected.
I do this to make the schematic as neat as possible and adding all your power lines makes it very messy.
Is there any way to do this in Diptrace?
Heres what I mean:
Thanks in advance :)
This is my right hand this is my wrong hand
Re: How to auto connect power traces from Schematic to PCB in Diptrace
« Reply #1 on: April 14, 2017, 04:56:38 pm »
OOPS NOOB me resister is not connected  |O |O |O |O |O :-DD
Offline DerekG
« Reply #2 on: May 12, 2017, 01:08:12 am »
When you look at your schematic, all the faint teal coloured squares are indicating that the connection has not been successful.
All the bight teal circles indicate that the connections are in-deed connected.
Just make sure you "grab" the component ends successfully (you can see as they change colour) before dragging the new wire to the next component. Then ensure the next component end changes colour before you "let go" of the new wire being placed.
I also sat between Elvis & Bigfoot on the UFO.
Offline Keicar
    • My YouTube Channel
« Reply #3 on: May 12, 2017, 01:28:15 am »
Yes, it's easy to miss those connections - I've developed the habit of hovering over each net with my mouse to check that everything that should be part of that net changes colour as expected.
Karl.
Offline DerekG
« Reply #4 on: May 12, 2017, 02:25:27 am »
Yep great idea.
For more than 25 years I used Protel/Altium but I mainly use DipTrace now as it is a very intuitive package that just gets better with every new release.
