Author Topic: How to manually add items to the BoM  (Read 6579 times)
Offline DigibinTopic starter
« on: March 17, 2015, 08:22:13 pm »
Hey, I've started using DesignSpark PCB and I was wondering if there's a way to add miscellaneous items to a project BoM. For example a board to board cable assembly that doesn't appear on the schematic itself? Or a component that RS don't stock?
Can it be done? If so, how?
Cheers.
Offline DerekG
Re: How to manually add items to the BoM
« Reply #1 on: March 17, 2015, 09:19:31 pm »
I can't answer your question above as I spent a month with DesignSpark last year before moving to an alternative package.
If the components you want to use are DesignSpark supported on the element 14 website, everything runs very easily.
However, when you need to make your own components, you will pull your hair out & wish you looked at alternative packages.
I use extensively Altium, Proteus & DipTrace (different companies I contract to have their preferences) & I found the component generation side of DesignSpark absolutely woeful.
I also sat between Elvis & Bigfoot on the UFO.
